Displays a Most posts widget.
(Example of Most posts widget) :
Installation :
Normally you will select Yes to the following User groups:
Registered
Unregistered / Unconfirmed
Cron entries :
This add-on updates the widget every hour. When you first install the add-on please run the Cron entries manually in order to see the widget :
Admin control panel -> Tools -> Cron entries -> Most posts
Questions and Answers :
Q: When do the post count numbers update?
A: They are updated once per hour by Cron entry.
Télécharger V1.9 :
Most posts v2.0 changes : Added Exclude secondary user groups to options page.
Télécharger V2.0 :
Most posts v2.1 changes : Fixed issue with limit not working correctly if some secondary user groups are excluded.
Télécharger V2.1 :
Most posts v2.2 changes : Updated CSS to fix color issues when a dark style is being used.
Télécharger V2.2 :
Installation :
- Download Andy-MostPosts-1.7.zip and unzip it.
- Copy the src/addons/Andy/MostPosts directory to your server.
- Admin Control Panel -> Appearance -> Widgets
- Widget definition = Most posts
- Widget key = most_posts
- Title = (leave blank)
- Display in positions = Forum list: Sidebar
- Click Save.
Registered
Cron entries :
Télécharger V1.9 :
Télécharger V2.0 :
Télécharger V2.1 :
Télécharger V2.2 :
