AndyB Featured posts 2.3
XF 2.0 / 2.1 / 2.2 AndyB Featured posts 2.3
Titre du sujet Titre du sujet AndyB Featured posts 2.3
Réponses Réponses 4
Affichages Affichages 450
Affiche un message aléatoire toutes les 10 minutes.
Le message est sélectionné dans un forum défini dans la page Options. Le premier message du sujet est sélectionné au hasard et sera affiché dans la liste du forum ou dans un autre emplacement de widget.
1397
1398
1399
  • Cron Entry will rotate posts every 10 minutes.
  • All phrases start with featuredposts_ for your convenience.
Installation :
  1. Download Andy-FeaturedPosts-1.6.zip and unzip it.
  2. Copy the src/addons/Andy/FeaturedPosts directory to your server.
Creating the widget :
  1. Admin Control Panel -> Appearance -> Widgets
  2. Widget definition = Featured posts
  3. Widget key = featured_posts
  4. Title = (leave blank)
  5. Display in positions = Forum list: Above nodes
  6. Click Save.
User group permissions :
Normally the following two groups are set to Yes:
Registered
Unregistered / Unconfirmed
Optional CSS :
If you would like to limit the size of images and media, you can add the following code to the andy_featuredposts.less template :
.bbImage {
    max-width: 200px;
.bbMediaWrapper, .bbMediaJustifier {
    width: 200px;
Télécharger V2.0 :
Featured posts v2.1 changes : Fixed issue where occasionally returned empty widget.
Télécharger V2.1 :
Featured posts v2.2 changes : Fixed issue where widget occasionally returned empty.
Télécharger V2.2 :
Featured posts v2.3 changes : Updated code to prevent possible null condition error.
Télécharger V2.3 :
XF 2.0 / 2.1 / 2.2 / 2.3  AndyB Email subscription 3.4
XF 2.0 / 2.1 / 2.2  AndyB First post length 1.5
Ajout de la version 2.1 :)
Ajout de la version 2.2 :)
Ajout de la version 2.3 :)
