L'add-on ajoute un ruban sur l'avatar pour mettre en évidence l'utilisateur qui a lancé le fil.
Here are the screenshots of admin pages/options available :
Demo : Original poster test
Version 1.3.0 Bug-fix : Misalignment of "Thread starter" in "Public Controls" location :
The release fixes a cosmetic issue with "Thread starter" not being aligned with the "Reply" link on XenForo 2.1.x versions. The issue affects you only if you have used "Text: Public Controls" for the indicator location and did not enable the option "Round Avatar Fix".
We have also added descriptions for the template modifications. If you use XenForo 2.1.x you will see that the modifications meant for XenForo 2.0.x fail to apply, and that's normal.
Télécharger V1.3.0 :
Version 1.3.0 Bug-fix: Minor UI changes in the admin panel :
In this update, we have changed the display order of the option group and the style property to show them after default XenForo items.
Télécharger V1.3.1 :
Version 1.4.0 XenForo 2.2.x support
This release implements XenForo 2.2.x support. The only issue we have reproduced was not adding the indicator next to the New indicator. If you have any issues and see any errors please let us know and we will resolve them asap.
Télécharger V1.4.0 :
Version 1.4.1 Bug-fix: deleted users are shown as original poster
In this release, we have fixed a bug with guest/deleted users being shown as the original poster.
Now, only posts made by a guest with the same username as the deleted thread creator will be marked as the original poster.
The add-on is verified to work with XenForo 2.2 and with some UI.X theme, particularly with
Télécharger V1.4.1 :
Version 1.5.0 New badge locations next to the post date :
In this release, we have added two new positions in the Style properties called
Télécharger V1.5.0 :
- Disable the product for particular styles.
- Style property that will define the ribbon color.
- Style property that will define the ribbon position Top Left corner/Top Right Corner/Top/Bottom.
- Ribbon/Text Position
Default
and Circle
avatar forms. In general, custom themes are not officially supported, so if you get any issue with the particular placement of the indicator, please check out other indicator locations.Télécharger V1.4.1 :
Text: Post Date (left)
and Text: Post Date (right)
. Positions are putting thread starter text indicator on the left or right side of the post date.Télécharger V1.5.0 :
