XF 2.1 / 2.2 / 2.3 [TH] Featured Threads and Content Portal 1.2.1 Patch Level 1
Titre du sujet Titre du sujet [TH] Featured Threads and Content Portal 1.2.1 Patch Level 1
Réponses Réponses 21
Affichages Affichages 1 716
Featured Threads and Content :
Attirer l'attention et maintenir l'engagement avec les discussions en vedette. Mettre en valeur vos sujets de discussion favoris et précieux donne à votre communauté un moyen simple de consulter certaines des meilleures informations sur votre site. Créez une page affichant les discussions en vedette et créez également un widget !
Administrator Features
  • Set up criteria to automatically feature threads with Thread, User, and User field criteria
  • Choose the order in which auto feature criteria will be checked
  • Choose how many featured items can be displayed per page
  • Choose the maximum excerpt length for featured items
  • Allow moderators to feature threads and polls
  • Create a widget to display featured content
  • Choose the number of featured content items to be displayed on the widget
  • Set the pixels you would like all uploaded slider background images to be
  • Determine how long content can remain featured or leave it featured indefinitely
  • Display a user’s current featured content on a "Featured content" tab on their member profile
  • Apply a prefix to featured threads
  • Show the first post at the top of all pages in the featured thread
  • Determine the size and style icons should be for the featured content
  • Add advertisements above and below feature message content
  • Choose whether or not users can dismiss features from widgets in permissions
User Features
  • Easily identify and view featured content
  • Have their currently featured content displayed on their member profile
  • Dismiss features from displaying in widgets if you have the appropriate permissions
Free Branding Removal
This add-on does include branding but it can easily be removed for free! More information on how to remove the branding can be found here.
Télécharger V1.0.2 PL1 :
Version 1.0.4 Change :
Bugs Fixed : "Show all featured items" link no longer incorrectly links to user ID 1
Featured item list no longer uses widgets, so items in the slider or grid will no longer show up in the main listing
New thread criteria to require the first post to have an attached image
Option to show first post at the top of the first page only instead of all pages
Version 1.0.5 Change :
Enhancements:
Option to autoplay slider
Ability to specify number of items on slider/grid for feature page
Rebuild tool to update feature metadata
Bug Fixes:
Filters now work on the slider and grid on the feature page
Moving a thread to a new node will update the category for feature page filters.
Télécharger V1.0.5 :
Version 1.0.6 change :
Enhancements :
Added XenForo Media Gallery support
Added XenForo Resource Manager support
Added Last Post criteria support
Bug Fixes :
Fixed an issue that caused an error when moving threads
Fixed an issue that caused feature count on user entity to get logged to the changelog
Version 1.07 change : Added attachment rendering for attachments embedded into featured excerpts.
Télécharger V1.0.7 :
Télécharger V1.0.8 Patch Level 1 :
Version 1.0.9 : Add thread specific widgets with sort options based on thread columns rather than feature columns.
Version 1.0.9 Patch Level 1 : Fix feature thread widgets not showing content.
Version 1.0.9 Patch Level 2 : Widget config fixes, widget Sort order fix
Version 1.0.9 Patch Level 3 : Fix for filters and pagination
Version 1.0.9 Patch Level 4 : Make grid pull grid content not slider content
Version 1.0.9 Patch Level 5 : XenPorta 2 for XenForo 2.x importer
Télécharger V1.0.9 Patch Level 5 :
Version 1.0.10 :
Restores Featured nav item
Fixes issue with missing 2x size icon
Adds default icon and background upload fields
Changes widget forum config to be a select and always show all forums not just ones with featured content
Télécharger V1.0.10 :
Version 1.0.10 Patch Level 1 :
- Fixes issue with thread last post date logic being incorrect
- Fixes issue with media item view criteria throwing error
Télécharger V 1.0.10 Patch Level 1 :
Version 1.0.10 Patch Level 2 : Fixes missing and broken phrases in job status messages.
Télécharger V 1.0.10 Patch Level 2 :
Version 1.0.11 :
- Add option for default sort order.
Télécharger V 1.0.11 :
Version 1.0.11 Patch Level 1 : Option to disable featured image cropping.
Télécharger V 1.0.11 Patch Level 1 :
Version 1.0.12 : Refactoring widgets
Version 1.0.12 Patch Level 1 : Fix for missing Featured relation
Version 1.0.12 Patch Level 2 : Rebuilds auto-feature rules when deleted
Télécharger V 1.0.12 Patch Level 2 :
Version 1.2.0 Patch Level 1 :
- Fix featured image from embedded attachments
- Compatible XF 2.3
Télécharger V 1.2.0 Patch Level 1 :
Version 1.2.0 Patch Level 2 : Fix thread reply modal
Télécharger V 1.2.0 Patch Level 2 :
Version 1.2.1 Patch Level 1 : Add support for WebP
Télécharger V 1.2.1 Patch Level 1 :
Ajout de la version 1.0.5 :)
Ajout de la version 1.0.9 Patch Level 5 :)
Ajout de la version 1.0.10 :)
Ajout de la version 1.0.10 Patch Level 1 :)
Ajout de la version 1.0.10 Patch Level 2 :)
Ajout de la version 1.0.11 :)
Ajout de la version 1.0.11 Patch Level 1 :)
Ajout de la version 1.0.12 Patch Level 2 :)
Ajout de la version 1.2.0 Patch Level 1 :)
Ajout de la version 1.2.0 Patch Level 2 :)
