Télécharger Multi Consoles mGBA v0.5.2 disponible pour PC, Vita, Wii et 3DS
Titre du sujet Titre du sujet Multi Consoles mGBA v0.5.2 disponible pour PC, Vita, Wii et 3DS
Affichages Affichages 632
Dernier message par Dernier message par AnonyNooB
Le développeur Endrift nous propose de découvrir une dernière version de l'année 2016 de mGBA, il s'agit de la version v0.5.2.
CCette version est une release de corrections de bugs plus que de propositions de nouveautés, elle apporte stabilité et moins de problèmes.
Bugfixes:
All: Fix fullscreen config option being ignored
ARM7: PSR mode bits should not get sign extended
GB: Fix audio not being deinitialized
GB: Fix crash when masking savedata
GB: Properly initialize sramRealVf variable
GB Audio: Fix serialization of channel 3 and NR52 properties
GB Audio: Reset envelope timer when reseting sound channel
GB MBC: Fix SRAM dangling pointer with RTC games
GB MBC: Fix initializing MBC when no ROM is loaded
GB Memory: Fix patching ROM bank 0
GB Memory: Fix starting HDMAs during mode 0
GB Memory: Fix HDMA5 value after DMA completes
GB Video: Initialize LCDC in renderer
GB Video: Hblank IRQs should mask LYC=LY IRQs
GBA: Fix IRQs firing after already being cleared
GBA: Only unhalt CPU if appropriate bit is set in IE
GBA: Add savegame override for Crash Bandicoot 2
GBA BIOS: Fix MidiKey2Freq BIOS reads
GBA BIOS: Fix invalid CpuSet not setting BIOS prefetch
GBA Cheats: Fix GameShark ROM patches
GBA I/O: Mask off WAITCNT bits that cannot be written
GBA Memory: Fix misaligned BIOS reads
GBA Memory: Fix VCOUNT being writable
GBA Video: Fix out of bounds sprite transforms
Libretro: Fix unterminated SET_INPUT_DESCRIPTORS
Libretro: Fix disabling BIOS
Libretro: Fix Game Boy savestates and audio
Qt: Fix changing resolution of software renderer
Qt: Fix setting overrides
Qt: Fix cut off tiles and alignment issues in tile viewer
Qt: Only reset window dimensions when first shown
Qt: Fix Qt Multimedia audio driver on big endian
Qt: Fix Apply button for key and controller configurations
VFS: Fix resizing memory chunks when not needed
Windows: Fix Unicode directory handling
Misc:
GB, GBA: Prevent loading null ROMs
GB Audio: Initialize wave RAM to GBC values
GB Memory: Reset ROM bank when loading a ROM
PSP2: Improved controller rumble
Pour rappel cet émulateur est compatible avec HENKAKU pour Pstv et Psvita, mais aussi Windows, Wii, et 3DS.
Téléchargement : mGBA v0.5.2
